2002 Nissan Sentra got a p0430 code
127,000 MILES • 4 CYL • FWD • AUTOMATIC
ECKOE760
I got a p0430 code and i wanna make sure it is not my cat thats gone wrong. i want to check the o2 sensors but i dont know what the voltage should be while on the car and warmed up. can you help me by telling me how i can test them and what the voltage should be? also what else i can test to make sure its not my cat?
Feb 9, 2010 at 5:38 AM
  • 110,248 POSTS
It should be between 0.4 and 0.5 at normal operating temp and running at 2000 RPM's.
Anything below 0.4 is lean and above 0.5 is a rich mixture.
Let me know if this helps, and thanks for using 2carpros.com.
Feb 9, 2010 at 4:21 PM
