Your new exhaust system will not help with the problem you are having. First off, we need to know the code(s) of the check engine light. The easiest way to test for fuel pump is to test fuel pressure by the fuel rail. You should have about 50 psi at idle. If you don't, then use the money for your exhaust to get a new pump. But we still need to know the codes.
SPONSORED LINKS
Wednesday, November 12th, 2008 AT 10:16 PM
