2002 Nissan Sentra Accelerator Sensor
147,000 MILES • 4 CYL • FWD • MANUAL
THDAME
I have a 2002 Nissan Sentra SE-R Spec V. There is apparently a problem with my accelerator sensor on the throttle body assembly. My car will suddenly loose power and the accelerator will fail to respond to the gas pedal. The Nissan people want me to replace the entire throttle body assembly. NAPA has a replacement sensor but because Nissan wants to replace the entire assembly, I'm not sure if it will function properly on the Spec V. Can I replace the just the sensor or must I replace the entire assembly?
Nov 5, 2009 at 3:21 AM
  • 75,988 POSTS
Hi thdame and TY for the donation
If its the throttle position sensor you can replace that yourself, be advised there's another sensor called Acceleration pedal position sensor. I recommend you check that too.
Nov 5, 2009 at 5:46 AM
