2001 Nissan Sentra starter
2001 NISSAN SENTRA
BRIANBRADLEY
2001 Nissan Sentra 4 cyl Two Wheel Drive Automatic
how do you remove a starter and where is it at
Mar 30, 2010 at 9:22 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Remove or disconnect the following:
Negative battery cable
Wiring at the starter
Bolts attaching the starter to the engine
Starter
To install:
Install or connect the following:
Starter and torque the bolts to 70 inch lbs. (8 Nm)
Starter electrical connections
Mar 30, 2010 at 5:49 PM
