2001 Nissan Sentra 4 cyl Two Wheel Drive Automatic
how do you remove a starter and where is it at
Mar 30, 2010 at 4:22 PM
BLUELIGHTNIN6
✓ASE Certified Mechanic
Remove or disconnect the following:
Negative battery cable
Wiring at the starter
Bolts attaching the starter to the engine
Starter
To install:
Install or connect the following:
Starter and torque the bolts to 70 inch lbs. (8 Nm)
Starter electrical connections
Mar 31, 2010 at 12:49 AM
