2001 Nissan Sentra Mass air flow valve.
78,000 MILES • 4 CYL • FWD • AUTOMATIC
KCTHYNE
I received a diagnosis by a mechanic, after much stalling, that my vehicle's mass air flow valve was bad and needed replacement. The cost quoted was ridiculous so I got online and purchased a cheaper non-Nissan brand, but identical, mass air flow valve and housing. Can I simply replace the valve myself to finally correct the stalling? Or does the internal computer need to be re-programmed to function with the new part? If so, how do I re-program the computer?
Jan 10, 2008 at 4:59 AM
LOSTINMARS
  • 222 POSTS
yes the sensors are expensive. they are a bosch design.
can't tell you if the aftermarket cheapy will work, i refuse to use them.
good luck.
Jan 23, 2008 at 3:56 PM
