2001 Nissan Sentra ECM says "No communications"
2001 NISSAN SENTRA
77,500 MILES • 4 CYL • FWD • AUTOMATIC
SSAP108
Hello, Have a 2001 Sentra 1.8L auto 77,500. need to get thru emmisions test.Failed due to "No communications" with ECM. Went to Autozone to see if there scanner would work & had same results.Car runs great & no check engine lamp.Is it possible that there could be a loose connection at the ECM? Thanks
Jan 25, 2009 at 3:01 AM
BILLYMAC
  • 2,204 POSTS
yes it is possible unplug the ecm and plug back in check all fuses and grounds billymac
Jan 31, 2009 at 4:09 AM
SSAP108
took car in to local nissan dealer & they diagnosed it as a bad ECM, They also covered the repair under federal emmisions warranty 8/80 law. Although I had to bring up the law they woundnt have otherwise.Thanks for your response.
Jan 31, 2009 at 11:15 AM
