2001 Nissan Sentra crank sensor
RUDE BOY
Engine Mechanical problem
2001 Nissan Sentra 4 cyl Front Wheel Drive Automatic 64. miles
i put a fuel pump in and the car is still not starting,will a crank sensor cause it not to start?
Jul 2, 2010 at 12:56 PM
SATURNTECH9
  • 30,869 POSTS
Yes it will check and see if you have spark if you don't then i would check into the crank sensor possibly being bad.
Jul 2, 2010 at 1:01 PM
