2001 Nissan Sentra
94,000 MILES • 4 CYL • FWD • AUTOMATIC
ERNIE THE CAT
My daugthers 2001 sentra (1.8 liter) had a problem code run by a local parts store identified as P1126 that the "throttle control motor relay is open" which we figured was just a relay. The nissan parts department at the local dealer says the that there is no separate relay and I have to replace the whole throttle body for $300. It also ran a code PO430 that the catalyst efficency is low for bank 2. I figured that might be solved when the relay problem is fixed. My daughter is a broke college student and I am a broke father paying for the broke college student. thanks for your help
Nov 11, 2008 at 2:09 PM
  • 31,937 POSTS
Hi there,
Yell you car is broke as well..... may be you can get a good used throttle body from a salvage yard, do this first and get the codes cleared, then see if the Cat cod is re installed, we can deal with that if and when it shows.
mark (mhpautos)
Nov 11, 2008 at 2:14 PM
