2000 Nissan Sentra Should I change my catalytic converter?
2000 NISSAN SENTRA
QUEENBLENA
Computer problem
2000 Nissan Sentra Two Wheel Drive Automatic 121000 miles
I had my check engine light come on a while back. I took it to a mechanic and he checked it on the machine and told me that my catalytic converter is bad. Because I was not to excited about the price of the part, he told me it was not necessary to fix it. The only thing it is doing is hurting my gas mileage. I travel a lot and want to make sure its not hurting anything else. Is there any possibility he is wrong and that it is hurting my engine? Should I go get it fix?
Jul 18, 2009 at 8:31 AM
STEVEW84
  • 673 POSTS
it won't mess with your gas mileage. If it does it probably won't mess it up enough where you notice it. The only problem that you MIGHT(not 100% sure) have is that it will clog up and cause a low power issue. If you replace the converter make sure that you replace it with an OE from the dealer. I have seen far too many converters not last that long with an aftermarket cat converter. HTH.
Jul 18, 2009 at 4:33 PM
