2000 Nissan Sentra Gauges not working
GUYANESEBOY21
Electrical problem
2000 Nissan Sentra 4 cyl Front Wheel Drive Automatic
My gauges dont work: Speed,Odo,Tach. First it happened while i was driving. The needle went past 120 mph and tach was stuck at 3000 rpm and odo was just blank. Now when i start it up needles dont move at all. They just sit as if the car is off. i am not sure if it is a fuse. if it is which one would it be. and if it has to be in a garage how much would it cost. Thank You
Jul 9, 2008 at 1:00 PM
KHLOW2008
  • 41,812 POSTS
Hi guyaneseboy21,
Look for the gauge fuse in under dash fuse box.
It could be a bad connection or ground behind the meter. Wiring problems do not have a fixed book time so not possible to provide any info in that.
Jul 12, 2008 at 8:36 AM
