2000 Nissan Sentra fuel pressure
17,700 MILES • 4 CYL • FWD • AUTOMATIC
TONYA0808
give it gas alittle at a time and it will rev but if you take it to the floor, it bogs totally down,,whats up with that?
Feb 27, 2010 at 7:06 AM
  • 75,988 POSTS
Inspect and test all the following could be one of it that's causing it-
Oxygen sensors.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Feb 27, 2010 at 7:14 AM
