2000 Nissan Sentra Factory wheel replacement
2000 NISSAN SENTRA
150,000 MILES • 4 CYL • 2WD • AUTOMATIC
UOFKATS
I have to replace my factory wheel/rim. I have contacted a salvage yard and they have 2 different wheels. The different option is related to the size of the circle/round opening in the actual wheel. There are 16 holes in the wheel.
The two options are 1 3/4" or 1 1/16".
Which is the correct size for my car?
Mar 1, 2010 at 12:47 AM
RACEFAN966
  • 5,029 POSTS
OK I can't tell you which fits yours as there are two different ones as you have been told. What you need to do is pull off a wheel and measure the center hole diameter and also measure the bolt pattern. To measure the bolt pattern you measure from one bolt then skip one and measure to the next, now measure from center of one bolt to far end of the other bolt this gives you bolt pattern size.
Mar 1, 2010 at 1:36 AM
