2000 Nissan Sentra Dash board lights
100,000 MILES • 4 CYL • FWD • AUTOMATIC
NADYA
Lately, whenever I drive my car, my brake and battery light are blinking randomly. Also, all the lights in the car (e.g. the headlights, the dashboard light, light in the car if it is on), oscillate (that is, become dimmer and brighter in sequence.) There does not seem to be anything wrong with my battery, and my brakes are fine too.
Also, the horn is not working. I got the horn checked over before, but nothing was found. Could it be that the two problems are related? What could be the problem with the dash board lights?
Jul 2, 2010 at 6:19 PM
KHLOW2008
  • 41,812 POSTS
Hi nadya,
Thank you for the donation.
There is a possibility the alternator is failing. I would suggest getting the charging rat tested first.
As to the horn not working, did you test if the horns work when battery voltage is applied to them?
Jul 5, 2010 at 9:49 AM
