On my Dash Board The Brake light pop on while I was driving. What could be the problem?
Jan 12, 2009 at 10:42 PM
ZACKMAN
✓Experienced Mechanic
Check your brake reservoir on your master cylinder. That light is to tell you the reservoir is low of brake fluid, which in turn to tell to check the brake system. Either you have a leak in the system, or the pads are just about done....
