1998 Nissan Sentra Rough start, misfires
JAF528
  • 1998 NISSAN SENTRA
  • 4 CYL
  • 183,000 MILES
I had a misfire in cylinder 2 while driving on the highway about a week ago, noticed considerable decline in power and car started riding rough. Replaced spark plugs and cap and rotor, wires were checked and ok. Still having misfires, only in cylinder two. Still riding very rough, starting very rough. A couple times had trouble starting it at all. Checked new spark plug in cylinder 2 and it was covered in dry carbon. Car burns oil, always has since 20k. Where do I check next? Could it be the fuel injector? Does the entire system need a carbon cleaning? Thanks!
Monday, December 28th, 2009 AT 12:26 PM
Check compression and injector for no.2 Engine misfiring can be caused by worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel.
Monday, December 28th, 2009 AT 2:44 PM
