1998 Nissan Sentra power window switch
1998 NISSAN SENTRA
101,000 MILES • 4 CYL • FWD • AUTOMATIC
MADAMS3031
the switch that opens the front driver side window has to be pushed really really hard befor it will work. are the contacts diryt? can I clean them? what should I try befor I replace it?
Mar 13, 2009 at 6:26 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello
Thanks for the donation
Yes, you can clean the contacts with electrical contact cleaner to see if it helps the switch any. If that does not help then inspect all of the wires to make sure they are clean and tightened properly. If wiring is OK it is time to replace that switch. If you need help removing the switch just let me know.
Thanks for using 2CarPros.com!
Mar 13, 2009 at 5:51 PM
