1998 Nissan Sentra power window master switch
167,000 MILES • 4 CYL • 2WD • AUTOMATIC
DKS13DKS
my front drives window will only go down not up. i tested the wires with a meter and i get a 12 reading going down and a 6 reading to raise it up. but the window does not go up. any idea where i should start to find this problem
Feb 15, 2009 at 2:38 AM
BILLYMAC
  • 2,204 POSTS
hi you need 12 volts to go up or down.did you check the master switch for the pass window does it have 12 both .if yes replace the master billymac
Feb 21, 2009 at 12:40 PM
