1998 Nissan Sentra Fuel Pump
1998 NISSAN SENTRA
WHANICO
Engine Performance problem
1998 Nissan Sentra 4 cyl Front Wheel Drive Automatic
Car wouldn't start. Replaced gas filter. Wanted to see if gas was flowing so I had someone crank the engine and gas came through. Somewhere I heard that there might not be enough fuel pressure. So, how does one check the fuel pump and the pressure?
May 1, 2008 at 1:55 AM
  • CAR REPAIR CONTRIBUTOR
You check fuel pressure by using a fuel pressure gauge to determine if the fuel pump is producing the correct pressure and it has to be within specification. Seeing it coming out of the fuel line don't mean nothing.
May 1, 2008 at 5:24 AM
