1998 Nissan Sentra Front cam seal troubleshooting
1998 NISSAN SENTRA
26,000 MILES • 4 CYL • FWD • AUTOMATIC
SCORPIO08
  • 8 POSTS
I have a 1998 Nissan Sentra with nearly 260,000 miles on it. Recently it developed an oil leak on the left side(facing the front of the car) of the engine, at least I think it's coming from the engine. Everything mounted in the area has a thin coat of oil on it. I took it to a garage and was told that it most likely was a front cam seal gone bad. My question is, how big of a repair job is a front cam seal replacement, and if you could give me a ballpark fiqure on what it most likely would cost? My concern is the number of miles on the car and if it turns out to be a costly repair, is it worth it. Will the leak worsen?
May 13, 2008 at 8:46 AM
  • 31,937 POSTS
Hi there,
This is not a big job. the front engine cover & cam belt will have to be removed & then the cam gear is taken off to access the seal. Time wise it should not take more than 2 Hrs.. The seal will be around $10-15 and you may wish the timing belt replaced as it is already removed. Ask your mechanic to give you a quote first.
Mark (mhpautos)
May 13, 2008 at 10:37 AM
