1997 Nissan Sentra Radiator fans not working
1997 NISSAN SENTRA
SUNNY83
Engine Cooling problem
1997 Nissan Sentra 4 cyl Front Wheel Drive
radiator fans are not working. but when we disconnect the ETC ( Engine Coolant Temperature Sensor) then fans starts working, what could be the fault?
thanks
May 30, 2008 at 2:11 PM
BLACKOP555
  • 10,386 POSTS
i would suspect a bad switch, because if its reading cool all the time then the fans will never come on.
May 30, 2008 at 2:39 PM
BLACKOP555
  • 10,386 POSTS
does it come on when the ac fans are turned on? if so suspect the switch or possible wiring harness error.
May 30, 2008 at 2:41 PM
