1997 Nissan Sentra overflow drain
TAUB4126
  • 1997 NISSAN SENTRA
  • 4 CYL
  • FWD
  • 170,000 MILES
How do I clear a overflow drain, it leak's water all over the passenger floor when ac is on. I tried to pull blower box out from behind glove box but it hanges up under dash with what I can see all mounting screws and bolts out. I dont want to take out upper dash out too. I put up on ramps and went under car to see if there was blockage at the tube on firewall and it seems clear. What can I do to fix this problem.
Sunday, July 13th, 2008 AT 11:09 AM
KHLOW2008
  • 41,814 POSTS
Hi taub4126,
The drain hole on which the tube is attached might be clogged. Did you try to clear it by pushing a wire through it?
From under dash, at lowest point of evaporator, check if the tube is kinked.
Saturday, July 19th, 2008 AT 12:59 PM
