1997 Nissan Sentra CV JOINTS?
141,000 MILES • 4 CYL • FWD • AUTOMATIC
HOWIEGREENE
Hi. Thinking about buying this car. In good shape except on left and right turns, makes a creaky noise. Seller says it needs new CV joints...is that true or is it something else?
Oct 12, 2008 at 2:25 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:4b64e5afbf="howiegreene"]Drive Train Axles Bearings problem
1997 Nissan Sentra 4 cyl Front Wheel Drive Automatic 141000 miles
Hi. Thinking about buying this car. In good shape except on left and right turns, makes a creaky noise. Seller says it needs new CV joints...is that true or is it something else?[/quote:4b64e5afbf]
Yes, a clicking sound when when turning or even driving straight depending on how bad they are, is a good sign of CV Axles being bad.
Oct 12, 2008 at 2:29 PM
HOWIEGREENE
Thanks for the answer! Do you have a general idea of what it would cost to replace them and how long I can drive on them before replacing them?
Oct 12, 2008 at 2:31 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:f37cb8704b="howiegreene"]Thanks for the answer! Do you have a general idea of what it would cost to replace them and how long I can drive on them before replacing them?[/quote:f37cb8704b]
The CV Axles will run around $150 or so each at a garage and the labor will depend on the rate in your area. I would guess between $500 and $600 maybe a little more like I said it will depend on labor rate in your area. Call around to some of the local garages a get a few estimates.
Oct 13, 2008 at 4:26 AM
