1997 Nissan Sentra alternator belt
13,000 MILES • 4 CYL • 2WD • AUTOMATIC
ALICIAMARE0913
how do you change the alternator belt and what does it look like
Sep 1, 2009 at 8:52 AM
JEEPFAN
  • 135 POSTS
to change the belt youll need to loosen the bolts on the alternator and adjust the tightening screw enough to get the belt on however you will also need to remove the a/c belt and water pump belt. the alternator belt should be a grooved belt. the others are v belts
Sep 21, 2009 at 5:59 PM
