Jack vehicle. Remove the wheel. Remove the axle nut. Remove tie rod. Remove ball joint nut. Break the axle shaft free from the steering knuckle. Break off the old clamp from the boot. Completely clean up the axle from grease and debris. Slide in the new boot, grease the joint liberally and attach the new clamps. Make sure you use CV axle plier to attach the clamps. Installation is reversed.
SPONSORED LINKS
Thursday, September 4th, 2008 AT 9:48 PM
