Other Category problem
1997 Nissan Sentra 4 cyl Automatic 107, 00 miles
I need some advice on how to seal up the truck from leaking when it rains on one side
Monday, December 24th, 2007 AT 11:10 AM
MECHANIC
Which one do you have a truck or a car? Either way might want to remove the window frame and weather seals-and put some sealer the one that looks like a tar-check the auto parts store.
Now if you have holes-could you use putty and fiberglass- or piece of sheet metal and riveted-
SPONSORED LINKS
Monday, December 24th, 2007 AT 11:47 AM
CAMCH07
MEMBER
Actually itis the trunk of the car that is leaking it has nothing to do with the window and there are no holes.
Monday, December 24th, 2007 AT 1:11 PM
MECHANIC
91-97 Sentras are known for that on the trunk-Find the hole and patch it up otherwise the spare tire compartment will rot out.
