1997 Nissan Sentra
ALVINLM
1997 Nissan Sentra
How do you replace the cv boot on the nissan sentra and what do you have to take a loose to do it
Aug 15, 2008 at 6:45 AM
ZACKMAN
  • 4,202 POSTS
Jack vehicle. Remove the wheel. Remove the axle nut. Remove tie rod. Remove ball joint nut. Break the axle shaft free from the steering knuckle. Break off the old clamp from the boot. Completely clean up the axle from grease and debris. Slide in the new boot, grease the joint liberally and attach the new clamps. Make sure you use CV axle plier to attach the clamps. Installation is reversed.
Sep 4, 2008 at 2:48 PM
