1997 Nissan Sentra
PHIL_MC2006
Noises problem
1997 Nissan Sentra
i want to make another inquiry regards to the noise in my cars' engine. When i start the car i get no squeaking noise from the engine. As i drive the car after 5 minutes it starts to squeak. When i recieved a diagnostic from the previous owner , it stated that the a/c compressor had a leak. Could this be the cause of the squeak or just in the belts. Also could the a/c compressor lock up eventually and tear the belt off as a result of this leak. just want to know because if i can just solve the squeak without replacing the compressor then i'll go without a/c
Jul 12, 2008 at 4:18 PM
JALOPYPAPA
  • 467 POSTS
I have seen a seized air conditioner compressor shred a belt. If that happened in the Sentra, you would not only be hot but stranded, since the same belt runs the alternator (well, you could still travel a short distance). A leak doesn't necessarily cause a compressor to seize, but I'd want to track down the cause of the squeak.
It may be coming from the belt or the bearing of any of the pulleys it runs: the alternator, the compressor, the compressor clutch or the tensioner. First, make sure the belt isn't loose. Push on it to see how much deflection it has. There should be only a little. If it's tight enough, next check to make sure it isn't worn or misaligned. Try squirting some water on the belt while it's running and squeaking (take care to stay clear of the belt and other moving parts). If the noise stops, the belt may need replacement or pulleys checked for alignment. If it doesn't, one of the pulley bearings is bad. You can try (with the car off) wiggling them to check for any play, or, while it's running, try to listen closely (again, watch out for moving parts) to see if you can tell more exactly where it's coming from.
Jul 15, 2008 at 5:00 AM
