1996 Nissan Sentra The Alternator?
1996 NISSAN SENTRA
127,257 MILES • 4 CYL • FWD • AUTOMATIC
THIERRY_06
The factory alternator needs to be change. I have a pretty good idear of what to do but not to sure. What steps i need to take to change my alternator?
Mar 2, 2010 at 2:32 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Disconnect the negative battery terminal.
Disconnect the 2 lead wires and connector from the alternator.
Loosen the drive belt adjusting bolt and remove the belt.
Unscrew the alternator attaching bolts and remove the alternator from the vehicle.
To install:
Install the alternator and retaining bolts loosely.
Install the belt and connect the wiring.
Adjust the belt as outlined in . Torque the retaining bolts to 25 ft. lbs. (34 Nm).
Mar 2, 2010 at 2:41 PM
