1996 Nissan Sentra speed sensor
210,000 MILES • 4 CYL • FWD • AUTOMATIC
JAMIJAMIK
my car won't pass the emissions test because of the code P0500. i replaced the speed sensor but it still shows the same code. my speedometer works. what can i do so my car will pass?
May 29, 2008 at 3:10 PM
KHLOW2008
  • 41,812 POSTS
Hi jamijamik,
Was the speedometer working before you replaced the speed sensor?
After replacement did you erase the error code?
I think you have a tuning problem rather than what you suggested.
A simple thing as a clogged air filter will cause you to fail the emission test. Get a tuneup done for your car.
May 31, 2008 at 4:18 AM
