1996 Nissan Sentra front Axle repair
100,453 MILES • 4 CYL • FWD • AUTOMATIC
JWEEZY
I installed both front axles and now my brakes sqeak. the previous axles were very worn dowm and clacking constantly. should I repace the brakes? Is this a normal problem with repair of front axles?
Mar 15, 2009 at 10:15 AM
ZACKMAN
  • 4,202 POSTS
Brake squeak has nothing to do with axle replacement. Did you happen to check how much pads you have. It is probably getting too close to the noise sensor. If you have not replaced the brake for more than 2 years, I would replace it.
Mar 15, 2009 at 6:11 PM
