1996 Nissan Sentra Driver side window
10,800 MILES • 4 CYL • 2WD • MANUAL
KRAMERJA01
The power window on the driver side of my car is not working. It started as just a problem rolling the window up. I would have to "help" the window go up by pulling it up. It goes down just fine but not it won't go up at all. and once it is all the way up is shifts down about an 1/4 of an inch away from the seal. Is this a motor issue or do I need to replace the whole window regulator. and is it something that I can do myself???
Feb 4, 2009 at 6:00 AM
SAWMASTER88
  • 38 POSTS
It may not be either the motor or the regulator, the window may simply just be out of the track. In order to find out though you will have to remove the interior door panel.
Feb 5, 2009 at 5:53 PM
