1995 Nissan Sentra radiator fan
1995 NISSAN SENTRA
APAC1321
Engine Cooling problem
1995 Nissan Sentra 4 cyl Two Wheel Drive Automatic 92k miles
my radiator fan has stopped working. it is plugged in and the fuse is good. what else can be done to find the problem?
Aug 11, 2008 at 4:00 AM
JALOPYPAPA
  • 467 POSTS
Check each of the three relays (identified on the cover) in the relay box in the engine compartment. Unplug each relay. The base should have plug-ins arranged something like this (ignore the periods; they're the only way I could add spacing):
..... ---- (2)
---(3) ........ | (5)
..... ---- (1)
While using jumper wires to connect fused battery voltage to terminal 2 and to ground terminal 1, you should have continuity between terminals 3 and 5. If the relays are OK, check the fan motor. Unplug it and connect jumper wires with fused battery voltage to terminal 2 and ground terminal 1. Looking at the oval shaped female plug, if the locking tab is at the top, terminal 1 is upper right, 2 is upper left.
Aug 11, 2008 at 3:34 PM
