1995 Nissan Sentra Noise
205,000 MILES • 4 CYL • 2WD • AUTOMATIC
BTFORTE
My 1995 Nissan Sentra make a thump sound every time I hit a bump. The sound seem as if the spare tire is loose or the car is bottoming because of bad struts. The spare tire is not loose and I have had three mechanic look at the struts and they are fine. Do you have any suggestion as to the problem that is causing the noise. Thanks.
Oct 2, 2008 at 3:37 PM
ZACKMAN
  • 4,202 POSTS
Check all bushings on your rear suspension, especially the ones on the torsion bar.
Oct 9, 2008 at 7:09 AM
