Code po400
DRUMMER21217
what to do next after replacing ERG valve? The check engine is still lit. do the computer need to be reset? Or do I need to do something else? I just bought the car three weeks ago from an auction so not much history.
Mar 14, 2007 at 4:15 AM
Good evening.
On the old OBD1 systems, when the correct repair is performed for a fault code, the light will go out on its own.
Since the light did not go out, the repair was incorrect.
Can I have the code number so I can help you with the repair?
Mar 25, 2020 at 9:56 AM
