1995 Nissan Sentra
1995 NISSAN SENTRA
20,000 MILES • 4 CYL • FWD • MANUAL
JIHAD
I installed my battery backwards. When I realized what I have done I flipped it back around. I went to start my car back up and it struggled the first time and then started. I would shut it off and it would start right back up, numerous amounts of times. I disconnected the battery, and I reconnected it, wouldn't start back up. I checked my battery fuse, that was burnt. So I replaced it. I also replaced my starter. Anything that involves a key in the ignition wont work. For example; the windows, sunroof, radio dash lights, starter. Did I fry my ECU or do I need a new ignition switch?
Dec 4, 2008 at 3:13 AM
JIHAD
Forgot to mention, my power door locks work, dome lights, and headlights. No lights from the dash work.
Dec 4, 2008 at 3:28 AM
ZACKMAN
  • 4,202 POSTS
Under left side dash, fuse box. Check fuses #
7 - sunroof, power windows
10 - radio
24 - audio
Basically check every single fuse in that box.
Dec 4, 2008 at 2:26 PM
JIHAD
I have checked every fuse in the car.
Dec 5, 2008 at 12:34 AM
ZACKMAN
  • 4,202 POSTS
Underhood Power Distribution Box Identification
Courtesy of NISSAN MOTOR CO., U.S.A.
Next to the battery, check
36 - 10 Amp Illumination, Tail Lights, Chimes
42 - 10 Amp Horn, ASCD, Theft
Fusible Link "F" - 25 Amp (Circuit Breaker) Power Window, Door Lock, Sunroof, Theft
Fusible Link "G" - 75 Amp Fuse Box
Fusible Link "I" - 75 Amp
Dec 5, 2008 at 1:23 PM
JIHAD
They all have been check and no fuses are burnt. The 75A fuse(battery fuse) did burn out, but I did replace it.
Dec 6, 2008 at 1:17 PM
ZACKMAN
  • 4,202 POSTS
Based on the wiring diagram, the only other things that has connections and has something to do with all of your problem is a 30A fuse, location (i) in the fuse box under the hood. That fuse controls the ignition key, from that it splits into two relays: ignition relay (runs among other things, windows, sunroof, A/C, dashboard, ACSD, and turn) and accessory relay (runs horn, wipers, and mirrors.)
If the fuse and the two relays are all good, you may have burnt your ignition switch. But before you replace the switch, check if you have power to the connector.
Dec 7, 2008 at 7:43 AM
