1994 Nissan Sentra Throttle getting stuck
BFLORES
Engine Mechanical problem
1994 Nissan Sentra 4 cyl Two Wheel Drive
1994 Nissan Sentra: The throttle is getting stuck wide-open when you press the accelerator. I�ve changed the Throttle Position Sensor but did not fix the problem, what should I check next?
Nov 13, 2009 at 4:39 AM
  • 75,988 POSTS
Hi bflores and TY for the donation
Inspect the throttle plate could be binding to include a kinked accelerator cable, also clean out the IACV-AAC and the FICD
Nov 13, 2009 at 8:17 AM
