1994 Nissan Sentra replace fuel injectors?
1994 NISSAN SENTRA
170,000 MILES • 4 CYL • FWD • AUTOMATIC
GEO1NJ
My sentra is only running on 2 cylinders. I checked and made sure there is spark going to the cylinders and also made sure the plugs were good. I also did a compression test on the first 2 cylinders and they seem to be fine. I was told its probably the fuel injectors. How can i test this to know this is the problem for sure?
Sep 17, 2008 at 2:04 PM
Check the injectors solenoid resistance or get it flow tested
Sep 18, 2008 at 6:45 AM
