1994 Nissan Sentra Possible Engine?????
1994 NISSAN SENTRA
133,000 MILES • 4 CYL • FWD • MANUAL
MRATHLETE_5
I bought this car off a friend who is a mechanic. The car had set for 8 months so when I drove it the thing kept cutting off on me at stop lights etc etc. I had the alternator and battery checked and it came back ok. I took it to another mechanic I know and he said it was the motor and thats why it kept cutting off on me. He said the motor should be getting 2500 something I dont remeber but was only getting 20. I told my friend this and he said it was not a motor issue. So I took it to him and he adjusted the idle control and it doesn't cut off anymore but when I get it up to speed it just sounds like something is missing like a spark plug is missing. And the battery light and the brake light continue to come on, what could be wrong with this car?
Jan 20, 2010 at 11:46 AM
Does the check engine light come On?
Get the battery and alternator load tested if okay check fuel filter and also test the airflow meter and throttle positon sensor-might want to inspect sparkplugs and cap/rotor
Jan 20, 2010 at 12:22 PM
MRATHLETE_5
I did have the battery and alternator tested at advance auto parts and it checked out okay. The check engine light does not come on only the battery and brake light. I do need brake pads that could be the reason the brake light comes on. Thanks I will check that stuff and replace if needed
Jan 20, 2010 at 3:57 PM
You need to get the charging system checked out thoroughly-the light is still on and its no charging
Jan 20, 2010 at 4:08 PM
MRATHLETE_5
The charging system checks out ok, I did notice that one of the battery cables looks a little rough
Jan 21, 2010 at 3:29 AM
