1994 Nissan Sentra Persistent Vibration with new tires and
1994 NISSAN SENTRA
23,500 MILES • 4 CYL • 2WD • AUTOMATIC
JOERUNR
My 1994 Sentra has a persistent front wheel vibration with new tires and rims installed. Old tires were half gone after 5,000 miles. Everything looks firm except some play in one of the axels. My 15 year mechanic does not want to condemn the axel since the vibration continues down hill and without power applied. The vibration is worst between 60 and 80. What could be the problem? He has examined, rebalanced carefully, aligned, changed a bad ball joint.
Jan 21, 2009 at 10:15 AM
ZACKMAN
  • 4,202 POSTS
Swap the tires from front to back. If the vibration now in the back, sth has to do with your tire. If the vibration persists in the front, I would check the hub bearing and/or axle. Or maybe even your tie rod ends...
Jan 21, 2009 at 7:16 PM
