1994 Nissan Sentra I CANT FIGURE IT OUT!
R.W.SMALLEY
  • 1994 NISSAN SENTRA
  • 4 CYL
  • FWD
  • 246,567 MILES
HOWS IT GOING?MY NISSAN SENTRA STARTED MISFIRING TODAY SO I CHANGED THE PLUGS AND WIRES. THAT DIDNT FIX IT.I CHECKED TO SEE IF ALL OF MY WIRES WERE FIRING, THEY WERE. WITH THE CAR RUNNING I PULLED THE WIRES 1 BY 1. THE #3 CYLINDER DIDNT MAKE A DIFFERENCE WHEN I PULLED THE WIRE OFF. ITS A CONTINOUS #3 MISFIRE. IS THAT A CLOGGED INJECTOR?
R.W. SMALLEY
Thursday, June 5th, 2008 AT 11:49 PM
  • 31,937 POSTS
Hi there.
It well may be a faulty injector, but make sure there is spark at that lead & the fuel injector is getting a pulse signal. Do a comp check as well to be safe.
Mark (mhpautos)
Thursday, June 5th, 2008 AT 11:53 PM
R.W.SMALLEY
EVERYTHING HAS SPARK, THE CAR RUNS BADLY. IT HAS AN OPEN EXAUST SO I CAN HEAR THE MIS CLEARLY. IT HAS A LOUD PUT WHEN IT MISES BUT THE #3 WIRE IS FIRING JUST NO COMBUSTION GOING ON. IT WAS RUNNING FINE ABOUT 3 HOURS AGO.I WENT TO GET SOME FOOD, 10 MIN. LATER I STARTED IT UP AND ONLY 2 CYL. WERE RUNNING SO I CHANGED PLUGS AND WIRES, NOW ONLY 1 ISNT WORKING. ITS CRAZY!
Friday, June 6th, 2008 AT 12:17 AM
