DTC P0154: LEFT BANK FRONT HEATED OXYGEN SENSOR
CAUTION:DO NOT reuse any HO2S that has been dropped from a height of 20" (.5 m) or more onto a hard surface, such as concrete.
NOTE:Right bank is the bank that includes cylinders No. 1 and 4. Left bank is the bank that includes cylinders No. 2 and 3.
NOTE:Before performing diagnostic procedure, follow testing procedure.
DTC Confirmation Test
Malfunction is detected when HO2S voltage is too high. Possible causes are:
HO2S circuit open or shorted.
Defective HO2S.
To set DTC, start engine and warm to normal operating temperature.
Turn ignition off and wait at least 10 seconds.
Start engine and let it idle for 2 minutes.
Start engine and let it idle for 2 minutes. Select MODE 3 with scan tool.
If DTC is detected, go to PROCEDURE.
Procedure
Loosen and retighten front HO2S to 30-44 ft. Lbs. (40-60 N.M).
Turn ignition off.
Disconnect ECM harness connector.
Disconnect appropriate front HO2S harness connector
Check continuity of White wire between right front HO2S harness connector terminal No. 2 and ECM harness connector terminal No. 62, or Green wire between left front HO2S harness connector terminal No. 2 and ECM harness connector terminal No. 94.
Also check circuit for short to ground and short to voltage.
Repair circuit as necessary and retest system. If circuit is okay, go to next step.
Inspect HO2S harness connector for water.
If water exists, repair or replace connector as necessary and retest system. If connector is okay, go to next step.
CAUTION:DO NOT use ECM ground terminals when measuring voltage.
Reconnect all harness connectors. Start engine and warm to normal operating temperature. Measure voltage between ground and ECM terminal No. 62 (right front HO2S) or No. 94 (left front HO2S) by backprobing. See Fig. 3 and Fig. 4. Increase engine speed to 2000 RPM. The following conditions should exist:
Voltage cycles from 0-0.3 volt to 0.6-1.0 volt more than 5 times within 10 seconds.
Maximum voltage is more than.6 volt at least once.
Minimum voltage is less than.3 volt at least once.
Voltage never exceeds one volt.
If operation is as specified, go to next step. If operation is not as specified, replace appropriate front HO2S and retest system.
No problem is indicated at this time. Problem may be intermittent
SPONSORED LINKS
Monday, April 19th, 2010 AT 7:59 PM
