1994 Nissan Sentra HEADLIGHT HIGH BEAM
1994 NISSAN SENTRA
121,000 MILES • 4 CYL • 2WD • AUTOMATIC
CANINE
THE R/FRONT HIGH BEAM WONT WORK, REPLACED BULB SAME STILL. WILL WORK ON LOW BEAM
Dec 22, 2007 at 5:30 AM
Check the wire that goes for the high beam its probably open or the bulb socket. Unable to find the problem tie in from the left side-should be the same color wire and you are good to go.
Dec 22, 2007 at 5:51 AM
CANINE
[quote:27ca36b3b8="rasmataz"]Check the wire that goes for the high beam its probably open or the bulb socket. Unable to find the problem tie in from the left side-should be the same color wire and you are good to go.[/quote:27ca36b3b8]
WHAT COLOR WIRE IS FOR THE HIGH BEAM?? THANKS
Dec 23, 2007 at 2:40 AM
Not familiar with the color code-try both of them at the left side-it should come On.
Dec 23, 2007 at 4:42 AM
