I have a 1994 Nissan Sentra LE with a 1.6 GA16DE engine with 103,500 miles.
I began to have a starting problem some time ago, and found some bad injectors.
Recently, a new start problem began, and I found a leaking injector o-ring.
Now, checking fuel pressure, when I turn on the key, the needle goes up to 43 PSI, then instantly falls to 10 PSI and slowly bleeds off to 0.
I see no leaking o-rings or injectors now and the engine runs very well, but is still a bit difficult to start at times, having to hold the accelerator down.
I suspect the fuel pump, but is it possible the crank sensor is faulty, cutting the pump off?
Any other thoughts would be appreciated as well.
Thanks
Chris
Thanks
Chris
Jul 24, 2010 at 2:55 PM
