1994 Nissan Sentra engine surge
1994 NISSAN SENTRA
217,000 MILES • 4 CYL • FWD • AUTOMATIC
MARCYHAEK
engine surges at a cruise, like 40mph and up
Jan 21, 2010 at 10:27 AM
Probable causes check and test the following below
Oxygen sensor
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Cap and Rotor
If it doesn't apply disregard it
Jan 21, 2010 at 10:34 AM
