1994 Nissan Sentra Engine Oil
RBT26
Engine Performance problem
1994 Nissan Sentra 4 cyl Automatic 207500 miles
My sentra has been using up alot of oil latley. I use it to go to work everyday about 30 min away. I go up and down a mountain to and from work. I usuall put valvoline 5-30 engine oil. And I do the oil change frequently. I resently had all the hoses and and selents replaced. The oil was using up quickly before and after the work was done. I trust the mechanic and he gaurantees me his work, i take in the car when it needs anything to him and i am always satisfies. Might I be using the wrong oil? thanks
Apr 2, 2009 at 2:26 PM
  • 75,988 POSTS
If its not leaking physically-have him do a compression check both dry and wet tests
Apr 2, 2009 at 2:44 PM
MINIDRIVR
  • 12 POSTS
[quote:0d35d18720="rbt26"]I resently had all the hoses and and selents replaced. The oil was using up quickly before and after the work was done.[/quote:0d35d18720]
Was the valve cover removed prior to the oil use?
I have that trouble with my 91, it all started after replacing the valve cover seal.
My thread is here.
https://www.2carpros.com/forum/here-vp532842.html#532842
Apr 18, 2009 at 10:24 AM
