1994 Nissan Sentra Car sputtering and smoking
KAHNE
  • 1994 NISSAN SENTRA
  • 4 CYL
  • 194,000 MILES
I recently changed my spark plugs and valve cover gasket, on my 1.6 motor. Every since then at low rpms the car wants to sputter or have no power like it's not getting gas, then it's folllowed by what I think is white smoke. But by reading ur site white smoke is coolant but this definatley smells like oil coming outta the exhaust. But holding hand over tailpipe leaves no oil residue. The plugs I bought and metal rings u screw onto the plug before putting in motor and we either lost one or one didn't come with the ring so we took one off the old plugs, only problem being they didn't seem to be made to come off. So we used pliars and forced the ring off and then onto the new plug. The ring was completly intact but was bent some while trying to get off the old one. Was wondering if the plug or maybe we didn't seal the gasket well enough could be causing this problem?
Saturday, August 30th, 2008 AT 3:10 PM
Test all the spark plug wires resistances and make sure it is in there and clicks when its set in. Also, test the coil primary and secondary resistances. Did you torque the plugs?
Thursday, August 2nd, 2018 AT 6:35 PM
KAHNE
Wanted to add that it only sputters at low rpm and then all of a sudden it seems to get it's power back and drives fine at around 35-40 mph. It is just after the sputtering it smokes big time. It does smoke some without the sputtering but I notice the big clouds of smoke while or after it is sputtering. Could the plug be causing the smoke?
Verify if its the correct type plugs and also check the closed and wide open throttle voltages on the throttle position sensor. Did you test the wires resistances?
Thursday, August 2nd, 2018 AT 6:36 PM
