MY CAR IS SPUTTERING DURING NORMAL ACCELERATION BUT IF I BARELY TOUCH THE ACCELERATOR RPMS GO UP FINE BUT IF I HIT IT LIKE IM GONNA TAKE OFF FROM A LIGHT IT STARTS SPUTTERING SO BAD THAT I HAVE NO POWER AND DOESNT WANT TO GO. IVE GOT NEW CAP ROTOR WIRE PLUGS AND FUEL FILTER ALSO HAVE A SHORT RAM INTKE ON IT. ANY SUGGESTIONS WOULD BE GREAT.
SPONSORED LINKS
Monday, September 22nd, 2008 AT 9:45 PM
ZACKMAN
MECHANIC
Check your timing. Make sure that it is correct at 6 - 8 BTDC. If you have the SE-R, then it is 13 - 17 BTDC.
Then check/clean you TPS sensor.
Thursday, August 2nd, 2018 AT 6:36 PM
NOEL6783
MEMBER
Thanks for the info I checked all that and found that the proformance coil that I installed went bad I hooked my stock coil up and holy cow it worked I was not happy that I spent 4 days tryin to figure out what the problem was but that was it. Thanks
