While bleeding the brake fluid hoses, should the car be running?
Mar 5, 2008 at 2:37 AM
SERVICE WRITER
✓Experienced Mechanic
No need to.
You can gravity bleed it by letting the bleeders open and allowing the fluid to flow down from the master cylinders. Just don't let the Master cylinder go dry.
