1994 Nissan Sentra Battery light & Brake light come on
110,000 MILES • 4 CYL • FWD • AUTOMATIC
MBRENCHL
My brake light and battery light come on together when I accellerate. At idle, the lights are not illuminated. Press the accellerator, the lights come on, let up on the pedal, and the lights go off.
Is this a short in the system or an alternator problem? I'm getting 13.85V from the alternator at idle.
Sep 28, 2008 at 1:10 PM
  • 75,988 POSTS
Check the alternator belt tension/load test the battery to check its conditon also make sure its cleaned and tightened properly. Double check all connections at the battery and alternator
Sep 29, 2008 at 9:08 AM
